lacp system priority change
Riccardo Romani
Hello , can someone give an answer?
if after having an active peer-link port-channel between a couple of nexus 7010 I change lacp system-priority on both boxes and then I add a new member interface on that port-channel , that interface will be aligned with new lacp system-priority value but the old member do not and so I have to reload those modules which include old member interface. Am I right?
Ivan Shirshin
Hello Riccardo,
Where did you see information that old member would not be aligned with new system-priority? I see nothing about it in the configuration guide:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_portchannel.html#wp1775745
Kind Regards,
Ivan
Kind Regards,
Ivan
