02-15-2010 12:12 PM - edited 03-06-2019 09:42 AM
Hello
6506--------------------------Loadbalancer
6506 gi 1/5 connect to loadbalancer giga 0/0
6506 gi 1/6 connect to loadbalancer giga 0/1
6506 is running CATOS
on 6506
vlan 5
description IN_balance
vlan 6
description Out_balance
int giga 1/5
switchport access vlan 5
int giga 1/6
switchport access vlan 6
How do I configure LACP on 6506 running CATOS and aggregate giga 1/7-8 to VLAN 5 && giga1/9-10 to VLAN 6
Solved! Go to Solution.
02-15-2010 11:55 PM
Hello Saquib,
CatOS is limited to OSI layer 2 operations so you cannot configure a L3 etherchannel on it.
the commands you have found on Reza's link should be enough to setup a L2 etherchannel using LACP.
My only doubt is that you may need to set the LACP system-id as this was a mandatory step in first IOS switches.
Edit:
command for port channel protocol applies to slot numbers = modules not to channel group number, so be aware of this difference
This example shows how to specify the LACP protocol for modules 2 and 3:
Console> (enable) set channelprotocol lacp 2,3
Mod 2 is set to LACP protocol.
Mod 3 is set to LACP protocol.
Console> (enable)
see
the other commands for setting LACP system-id, LACP port priority are optional
Hope to help
Giuseppe
02-15-2010 12:55 PM
Hello saquib
Please refer to this config guide for configuration example using cat OS
Reza
02-15-2010 09:56 PM
Hello Reza
Is this the only command needed to configure LACP on catOS switch
set channelprotocol lacp 1
set port lacp-channel 1/1,1/2 mode active
on IOS the config was
Switch(config)# interface port-channel 1Switch(config-if)# ip address 172.32.52.10 255.255.255.0
02-15-2010 11:55 PM
Hello Reza
on IOS the config wasSwitch(config)# interface port-channel 1
Switch(config)# interface range fastethernet 5/4 - 5
Switch(config-if)# no switchport
Switch(config-if)# no ip address
Switch(config-if)# channel-group 1 mode active
Can you help with config steps for LACP L2 Etherchannel and LACP L3 Etherchanne
Hi ,
Following commands are used to configure LACP in cat os
set channelprotocol lacp 3
set port lacp-channel 3/33-34
set port lacp-channel 3/33-34 mode active
For more information check out the below link hope that helps !!
If helpful do rate the post
Ganesh.H
02-15-2010 11:55 PM
Hello Saquib,
Edit:
Console> (enable)
see
Hope to help
Giuseppe
02-16-2010 07:05 AM
Thanks Reza
Thanks Giuseppe
