Showing results forĀ
Search instead forĀ
Did you mean:Ā
Lan-2-Lan
opnineopnine
Hi all,
Please can someone explain me about the lan-2-lan is this only via vpn? or I can have this configured in my routers?
Thanks.
http://www.netcraftsmen.com/working-with-eompls/
https://cciethebeginning.wordpress.com/tag/eompls/
5 Replies 5
Reza Sharifi
Can you explain what you mean by "lan-2-lan"?
I have a customer requesting a lan to lan configuration, with router via mpls, and I only fond vpn connections.
thanks
Perhaps what your customer desires is to extend a LAN (L2) across a MPLS WAN.  If so, that should be doable.  Perhaps EoMPLS?
Hello Joseph,
Is there any example you can share?
thanks.
