LAN Bridging
battanc
I need to connect two office with the same IP class through a serial line (direct serial line, no MPLS ....).
Both LAN have 192.168.50.0 /24 and I can NOT change IP.
Witch solution ?
Two routers with L2TP ?
Two Switch (Layer-2 or Layer-3 ?) with L2TP ?
Or ?
Thank's
Claudio
paolo bevilacqua
Why you can not change IP? For sure you can.
Avoid bridging on WAN, it will give you troubles only.
Paolo, of course I can ...
But for my custom this is a BIG trouble, so he prefer not to change.
I know that the best solution is to change IP and only and simple route the LANs ..
Claudio
rsimoni
NAT?
In the "main" office I need only one IP class, this is the problem.
I have to NAT - on the Router in the main office - the 2-3 remote IP to an "internal" IP
But I believe this don't work
Claudio
