LAN connectivity
ShahabAhmad4412
Hi... sir i have cisco 2960-G switch and i have 3 different wan (internet) vendors of CIR ...i want to increase my bandwidth ...So i am facing a problem that how i can add this 3 different bandwidth  in a cisco and get single bandwi output in a single port ....can it is possible or i can buy load balancer plz help me....
Deepak Kumar
Here, Be honest, you will need a load balancer where you can decide or take a decision for bandwidth sharing based on the bandwidth available from the ISP end.
Are you using the default route for all ISPs or it is BGP or other routing protocol? If you are using default route or dynamic routing then load balancing is possible (depends on dynamic routing). But I hope you need some type of NATing and where is it configured?
If you will share a network diagram with us then it will easy to explain the same.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
