LAN design
NBouassiba
am planning to design an Local area Network in our company. I drafted an configuration for the core1 catalyst ( cisco catalyst 6509). Can someone check the configuration ? see the attachments
Thank you for you Help
Giuseppe Larosa
Hello Noureddine,
make sure that core1 and core2 are root bridges for all vlans (primary and secondary).
Depending on the fact if datacenter switches are acting as L3 or as L2 you may need to change the connections.
in any case direct link between them can be redundant.
Hope to help
Giuseppe
Hi Giuseppe,
the datacenter switches are acting as layer 3 switches.
Thank you for your Feedback
Noureddine
