Lan light switch
What is the difference between lan light swtich and lan base software switch
Jon Marshall
From the 2960 Q&A
Q. What are the advantages of Cisco Catalyst 2960 Series Switches with the LAN Base software relative to Cisco Catalyst 2960 Series Switches with the LAN Lite software?
A. Cisco Catalyst 2960 LAN Base switches deliver intelligent services for branch offices and wiring closets. The LAN Base IOS software supports enhanced Layer 2+ security, quality of service (QoS), availability, and scalable management to enable new converged applications. Catalyst 2960 LAN Base switches include both 10/100 Fast Ethernet and 10/100/1000 Gigabit Ethernet connectivity in 8-, 24-, and 48-port configurations.
Cisco Catalyst 2960 LAN Lite switches are for entry-level branch office and wiring closet networks. They simplify the migration from nonintelligent hubs and unmanaged switches to a fully scalable and reliable network. The LAN Lite IOS software supports standard Layer 2 security, QoS, and availability while lowering the network total cost of ownership. Catalyst 2960 LAN Lite switches deliver 10/100 Fast Ethernet connectivity in 24- and 48-port configurations.
All Cisco Catalyst 2960 Series Switches have technical support service options available through Cisco SMARTNet® service. All come with a Limited Lifetime Hardware Warranty, and LAN Base and LAN Lite software updates are provided at no additional cost.
Full link
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/prod_qas0900aecd80322c37.html
Jon
