09-11-2005 01:02 AM - edited 03-05-2019 11:37 AM
Anyone encounter this weird uti before? I have few 2500/2600 routers are having same problem. They are just for interfaces LAN/Token Ring only.
Is that IOS bug?
09-11-2005 03:32 AM
do you have network management systems polling your router ?
Try to turn on CEF and see if that makes a difference, also, have a look at this document:
IP Simple Network Management Protocol (SNMP) Causes High CPU Utilization
http://www.cisco.com/warp/public/477/SNMP/ipsnmphighcpu.shtml
GP
09-11-2005 04:21 AM
Hi GP,
I do have snmp enable. 1 srtring is for ciscowork. The other string is for monitor purpose. However, I do not have cef enable. I realized that every 4 hours the usage will hit 99%. I think most probably is cause by SNMP.
I will check it out the document. Thanks.
