02-07-2012 01:12 AM - edited 03-07-2019 04:46 AM
Hi forumers'
I am setting up a cisco smart install platform for my large amount of catalyst switch deployment POC environment.
I use C3560 switch to become the smart install director. It load with c3560-ipservicesk9-mz.122-55.SE1.bin.
My client switch would be all identical C2960s series. My C2960s series product variant would be below 5 types.
a. C2960s 24PD-L
b. C2960s 24PS-L
c. C2960s 24TS-L
d. C2960s 48FPS-L
e. C2960s 48TS-L
My initial plan was trying to use vstack group built-in to group all identitcal PID switch in a group, but somehow when i drill down on the confit it was showing this and stuck me to proceed
director_switch(config)#vstack group built-in 2960s ?
24-2sfp 2960s 24port 2 sfp port switch
24-2sfp-poe 2960s 24 port 2 sfp port poe switch
24-4sfp 2960s 24 port 4 sfp port switch
24-4sfp-poe 2960s 24 port 4 sfp port poe switch
48-2sfp 2960s 48port 2 sfp port switch
48-2sfp-poe 2960s 48 port 2 sfp port poe switch
48-4sfp 2960s 48 port 4 sfp port switch
48-4sfp-poe 2960s 48 port 4 sfp port poe switch
Question
a. How to match the Product ID with the director switch vstack configure?
Noel
Solved! Go to Solution.
02-07-2012 02:17 AM
DO NOT USE 12.2(55)SE1. Use 12.2(55)SE4 instead.
C2960s 24PD should be "24-2sfp-poe"
C2960s 24PS should be "24-4sfp-poe"
C2960s 24TS should be "24-4sfp"
C2960s 48FPS should be "48-4sfp-poe"
C2960s 48TS should be "48-4sfp"
Please don't forget to rate our useful posts. Thanks.
02-07-2012 02:17 AM
02-08-2012 10:07 PM
Thanks for the rating. I'm happy to see it works.
