01-28-2018 09:29 PM - edited 03-08-2019 01:35 PM
Dear Members/Experts,
We are replacing the Core infrastructure in Building -2 as depicted in the diagram. The Core switches will be Nexus 9k's. These N9k's should talk to one 6509 Core switch in Building-1.That is 10.100.0.0/16 should be able to talk to 10.200.0.0/16. I need to have layer3 communication between them, however vpc does not support Layer 3 and supports Layer2. I cannot have layer2 communication for other reasons.
Please find the diagram attached.
Need our suggestions and help.
01-29-2018 03:44 AM
Just a suggestion. Instead of connecting the two Nexus 9372s to the 6509 using a vPC, why not just make it two separate L3 links? One L3 connection between the 6509 and each of the 9372s. This will give you the necessary redundancy and to some degree load balancing.
Hope this helps
01-29-2018 03:55 AM
Agree. If using L2 communication is not an option, then don't use VPC, use L3 links.
01-30-2018 08:14 PM
Hi Chris,
Apologies for the delay in responding back.
Yes that is a good idea. So will the configuration will look this.
At 6509 end
Int vlan 1
ip address 1.1.1.1 255.255.255.0
int te1/1
switchport
switchport mode access
switchport access vlan 1
int te1/2
switchport
At N9k1.
Int vlan 1
ip address 1.1.1.2 255.255.255.0
standby 1 ip address 1.1.1.3
int eth1/1
At N9k2
Int vlan 1
ip address 1.1.1.4 255.255.255.0
int eth1/1
Would request you to confirm if this approach is right ?
Deepak George
01-30-2018 08:19 PM
Hi Chris,
Or do you suggest you the template below.
========= N9K =========
interface E3/3
description ## ##
logging event port link-status
mtu 9216
channel-group 1 mode active
no shutdown
interface port-channel1
description ## CORE-01 Connectivity ##
no ip redirects
mtu 9216
ip address x.x.x.x/30
========6500=========
interface xx
description ## ##
no switchport
mtu 9216
channel-group 3 mode active
logging event link-status
load-interval 30
carrier-delay msec 0
no shutdown
interface port-channel3
description ## Towards N9K ##
no switchport
mtu 9216
no ip redirects
no ip proxy-arp
load-interval 30
no shut
Deepak
01-31-2018 03:32 AM
If there is going to be only a single link between the 6509 and each of the Nexus, I would suggest making each of the links their own /30. I don't think it would be necessary to create VLAN interfaces or port channels for each connection, but instead just make each port a L3 port.
You'll probably also want to peer between the Nexus on a VLAN that goes across the switch's peer link. That's the way I do it across Nexus 5Ks. I assume it would be the same across the 9Ks.
