Layer 3 conncection betwenn VSS and N7K
jspichalla
Beginner
Beginner
I need a L3 conection between a VSS Cluster and 2 Nexus 7000. Is ECMP the best solution?
Jens
Reza Sharifi
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
ECMP would work fine when using layer-3 from the N7Ks to a pair of 6500 (VSS).  They would need to be fully meshed.
Have a look at this doc for more info:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/Borderless_Campus_Network_1.0/BN_Campus_Technologies.html#wp1103296
thanks for your fast response. Which version is better, 4 dedicated connections (full meshed) from the N7Ks to the VSS cluster or built 2x L3 MEC between this systems?
Jens
Hi Jens,
Fully meshed for a total of 4 connections.
Recognize Your Peers
