Layer 3 Etherchannel
ruanthekid
Good Day.
How do I get Layer 3 etherchannel to communicate with my Management VLAN ?  My etherchannel is Up Up, but my VLAN stays DOWN DOWN.
Any help will be much appreciated......
Here is a sample of my configs
Core 6807 XL
interface Port-channel50
 no switchport
 ip address 10.34.0.2 255.255.255.254
 ip ospf network point-to-point
interface TenGigabitEthernet1/2/1
 description # Link to Distribution 0 West Wing #####
 no switchport
 no ip address
 channel-group 50 mode on
interface Vlan60
 description # Management VLAN #####
 ip address 10.34.1.1 255.255.255.224
 no ip route-cache
router ospf 100
 router-id 10.34.0.129
 log-adjacency-changes
 nsf
 network 10.34.0.2 0.0.0.1 area 0
 network 10.34.0.129 0.0.0.0 area 0
 network 10.34.1.0 0.0.0.31 area 0
Distribution 4900
 description # Uplink to Core Switch #####
 ip address 10.34.0.3 255.255.255.254
 ip ospf message-digest-key 10 md5 7 1104391103005A0E577E7C
 flowcontrol receive on
interface TenGigabitEthernet1/1
 no switchport
 no ip address
 ip ospf message-digest-key 10 md5 7 03097B1F121D704E1D5D4E
interface Vlan60
 ip address 10.34.1.34 255.255.255.224
 standby 60 ip 10.34.1.33
 standby 60 priority 108
 standby 60 preempt
router ospf 100
 router-id 10.34.0.133
 redistribute static subnets
 passive-interface default
 no passive-interface Port-channel50
 network 10.34.0.133 0.0.0.0 area 0
 network 10.34.1.0 0.0.0.31 area 1
Mady Gueye
add least one physical port on the vlan
devils_advocate
Level 7
Level 7
An SVI will only come up if an active Layer 2 ports either exists in than Vlan (i.e an access port) or a Trunk port which carries that Vlan tag.
Your connections to other switches are Layer 3 (i.e they have an IP address) so as far as the switch is concerned, the SVI is not needed as there is no active ports requiring it.
A vlan is a layer 2 entity so it will not be tagged across your Layer 3 link, hence why the SVI believes its not yet needed so stays down.
If you just need an IP address for management of the device then use a Loopback interface as they are virtual also but do not require an active Layer 2 link to come up.
