Layer 3 Switch act as Layer 2 switch
Caitlyn Sims
I have a question regarding my layer 3 switch. Currently, the network works fine except that the layer 3 switch (which is Curly) cannot ping outside the management VLAN, and other devices cannot ping it. Moe can ping all devices fine.
So, my question is, how do I get Curly to ping the PC's and other router interfaces. I have not had much experience with the 3560 switch. Any help would be greatly appreciated
All I can say is that we have seen bugs with the software you are using before and the switches don't always behave as real world switches would.
That is not a satisfactory answer but the behaviour is not what you would expect to see unless I am missing something really obvious.
It is, as far as I can tell, definitely not due to your lack of understanding and I don't think you have configured anything incorrectly.
You may want to post this question using the link Dan provided above as they will have a lot more people using the same software and they may spot something I have missed or recognise a bug I am not aware of.
Sorry I couldn't be of more help but if you do find an answer would be interested to hear it :)
Jon
24 Replies 24
Jon Marshall
Cannot read your attachment but at a guess if the L3 switch is not routing and has just a L3 vlan interface for management then you need to add -
"ip default-gateway x.x.x.x"
where x.x.x.x is the L3 interface on another of your devices that is responsible for routing the management vlan.
Jon
Hi Jon,
Sorry about the attachment, wouldn't let me upload just the packet tracer file and had to zip it up.
The L3 switch already has a default gateway, that of the IP address of the router sub interface of the management vlan.
VLAN 452 is the management VLAN, and in the picture the default gateway for the switch is the same as the sub interface on the router.
I actually meant not all of us have access to the software you are using so best to attach configurations and a diagram.
It sounds like it is setup correctly with it's default gateway.
Assuming the L3 switch only has one SVI ("int vlan x") and that is the management vlan and assuming that the trunk connection is allowing the vlan then can you make sure IP routing is not enabled on the switch otherwise it will ignore the default gateway setting.
If that makes no difference attach configurations and diagram.
Jon
Ok, sorry, I'm very new to this forum.
I have attached the device configs for Larry (the router) and Curly (the L3 switch), and also the diagram
No need to apologise :)
Okay, your configurations look good at the moment.
So from the switch can you ping 83.174.64.206 ?
Can you also post from the switch the following -
"sh int trunk"
"sh ip route"
"sh vlan"
Jon
Yes, the switch can ping 83.174.64.206 and ....204 (which is Moe).
Again it all looks fine.
Just to clarify do all devices use the router as their default gateway IP in the respective vlans ?
Jon
Yes. While I was testing yesterday I checked and both the pcs can ping each other, and moe can ping every sub interface of the router, but curly can only ping the vlan.
Yes, that's correct. L3 switch cannot ping outside of the management VLAN.
Here is the spanning tree vlan 452
Curly#sh span vla 452
VLAN0452
Spanning tree enabled protocol ieee
Root ID Priority 25028
Address 00E0.F774.E59E
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 25028 (priority 24576 sys-id-ext 452)
Aging Time 20
Interface Role Sts Cost Prio.Nbr Type
Fa0/11 Desg FWD 19 128.11 P2p
Po1 Desg FWD 9 128.27 Shr
F0/11 is the connection to the router and Po1 is an EtherChannel link to Moe, the L2 switch
And the arp table after trying to ping 83.174.64.190
Curly>sh ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 83.174.64.190 0 0001.6499.8402 ARPA Vlan452
Internet 83.174.64.205 - 00E0.F774.E59E ARPA Vlan452
You should not see an arp entry for 83.174.64.190 because, unless I have got my maths wrong,  it is in a different IP subnet.
The only arp entries you should see would be for devices in the same vlan/IP subnet as the L3 switch.
It looks like the switch still thinks it should be L3.
This should not make a difference but can you on the switch administratively shutdown all the other vlan interfaces except the management one obviously.
Jon
Hi Jon,
This is what appears as it is freshly opened, with the other vlans shutdown.
Curly>sh ip arp
And yes, 83.174.64.190 is in a different vlan, the final usable address in the vlan before I believe.
If you now ping 83.174.64.190 what you should then see in the arp table is an entry for 83.174.64.206 ie. the default gateway for the management vlan.
Can you try that and post results.
Jon
