Licensing Crypto Modul
Vusal .P
Hi guys. Maybe my questions is funny. But i cant find any documentation.
I tray configure ASR 1001HX router. I need 10 GB IPsec throughput performance.
For this I select  "Cisco ASR1001-HX Crypto Module with no default throughput" (ASR1001HX-IPSECHW)
  When I selected that module configurator required for me FLSA1-1HXIPS8G (Crypto throughput License for ASR1001-HX 8G) or SL-ASR1-SEC-HX (Security Solution License for ASR1001-HX and ASR1002-HX)
What is the difference both of that? Can you help us?
Thank You
premsuraboyina
SL-ASR1-SEC-HX - The security solution license was made to be more consistent with ISR licensing, and includes IPsec + FW. Default throughput for the solution license is 8G IPsec.
FLSA1-2HXIPS8G - This gives only 8G IPsec throughput.
You can select either of the two.
If you want 10G throughput you need to upgrade to 16G from 8G (FLSA1-2HX8G16G).
Hope this helps.
pa8297@att.com
I think you can only get 8 or 16 gig
