Join Customer Connection to register!
215
nokoya001
Beginner
limiting bandwith of two port same vlan
Here is the diagram
Internet  <--> .Cisco ASR  <--> Cisco 3750
2 server connect to Cisco 3750 on port gi1/0/3 and gi1/0/7 get internet thru ASR with portchannel 1.101
These are the config of ASR
interface Port-channel1.101
encapsulation dot1Q 101
  ip address 103.2.0.1 255.255.255.0
  ip address 103.2.1.1 255.255.255.0 secondary
  no ip redirects
  no ip proxy-arp
end
And these are config of gi1/0/3 and gi1/0/7 which is same.
interface GigabitEthernet1/0/3
  switchport access vlan 101
  switchport mode access
end
Questions:
1. How can I limit vlan 101 bandwidth to maximum 50mbps going to outside of the internet ?
2. Should I do it on ASR or 3750 ?
3. With policy-map ? Could you give me an example.
Thanks in advanced.
1 ACCEPTED SOLUTION
Georg Pauwen
VIP Expert
the config below should limit VLAN 101 to 50MB out:
platform qos port-channel-aggregate 1
class-map VLAN_101_CLASS
match vlan 101
policy-map VLAN_101_POLICY
class VLAN_101_CLASS
police cir 50000000
conform-action transmit
interface port-channel 1.101
service-policy output VLAN_101_POLICY
Here is the step by step syntax:
ASR#conf t
ASR(config)#platform qos port-channel-aggregate 1
ASR(config)# class-map VLAN_101_CLASS
ASR(config-cmap)# match vlan 101
ASR(config-cmap)#exit
ASR(config)# policy-map VLAN_101_POLICY
ASR(config-pmap)# class VLAN_101_CLAS
ASR(config-pmap-c)# police cir 50000000
ASR(config-pmap-c-police)#confirm-action transmit
ASR(config-pmap-c-police)#end
ASR#conf t
ASR(config)#interface port-channel 1.101
ASR(config-subif)#service-policy output VLAN_101_POLICY
1 REPLY 1
Georg Pauwen
VIP Expert
match vlan 101
police cir 50000000
ASR#conf t
ASR#conf t
