Highlighted
(Linecard image not present) at WS-SSC-600 and 7600-SIP-400
i install two modules WS-SSC-600 and 7600-SIP-400 in slot 5 and 6 in 13-slot chassis and give this output from show power (Linecard image not present)
  for both cards.
supervisor engine is : VS-S720-10G with sub-module VS-F6K-PFC3CXL and VS-F6K-MSFC3
IOS : s72033-advipservicesk9-mz.122-33.SXI9
what that mean and how to fix it ?
8 REPLIES 8
Highlighted
Hall of Fame Expert
On the SIP card, is there an LED light, if yes, what color?
Highlighted
surry for late the two modules - are not powered up so - LED is not light
Highlighted
do you have any idea about this output and why the modules are not powered off.
thanks
Highlighted
hum... reinsert the linecard ;)
Highlighted
i will test and feed you back . But i need to sure from slote number i put them in slot 5 and 6 at 6513 chassis is it correct or need to change slot number?
Highlighted
also i need upgrade IOS or not?
Highlighted
Ok problem solved by upgrade ios to another version but the new image must contains (_wan) in image name for example (
s72033-advipservicesk9_wan-mz.122-33.SXJ6 ) otherwise the two modules will not powered up.
Highlighted
Done thanks
Content for Community-Ad
