Linksys SGE2000P L3 mode
Hello Guys.
I have several Linksys SGE2000P switches in my network, i was checking the datasheets for these switches and they indicate that these switches can do Layer 3 routing, i need to setup VLANs in my network then use a Linksys SGE2000P switch to do the Inter-VLAN routing between the different VLANs. How do i configure the switch to operate in Layer 3 mode, i cannot see any settings in the GUI for configuring L3 routing.
Thanks.
educruz
Below one can find the reference guide. There is a section for Layer 2 and Layer 3 setup.
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sge2000/reference/guide/sge_refguide.pdf
Hope this helps. Let me know if it does not.
- Ed
