LMS 4 problem
nir.fisher
hello ,
I recenly installed LMS 4 on a windows 2008 R2 system , I didnt change the default configuration of windows or ciscoworks
I just added devices and configured basic things on the LMS system .
when I open ciscoworks on the server itself it starts a browser session on http port 1741 and then changes automatically to https even though
the default config is browser security disabled on ciscoworks.
I try to open a browser session on a mgmt station to the cisco server , it didnt work in https ( I did get the login screen but couldnt log on , probablly something to do with the certificate ) , so I open http on port 1741 and it worked , I was able to log in .
After a few Hours for some strange reason I didnt have access any more from the mgmt station not in http nor in https , the only way was to access
it from the server itself .
I went and changed the default setting of the secure browser on LMS 4  hopping that would work , I was asked to restart the ciscoworks service for
the changes to take affect , I tried to restart it but it was unsuccesful so I restart the whole server.  when it came up ciscoworks didnt work
most services didnt start ( like the web server ,tomcat and all the manual serivices and ciscoworks deamon)
please help me if you have any ideas what to do
if ypu need more information I will gladly provide , thanks
Jon Marshall
Nir
You may want to move this to the "Network Management" forum where they have extensive expertise in LMS issues and you would be far more likely to get an answer to your question.
Jon
I didnt realize there were such a group
I post my question there
thanks
