Load balance
ntmanjunath
I need to configure load balance in Cisco router.
The single router WAN interface connected two ISP, one ISP connected serial0 and another ISP is serial1 both the ISPs provided 2MB bandwidth. The LAN side f0/0 and f0/1 connected firewall. I need to do load balance in the router end. Please let me know the sample configuration.
Hi Manju,
pls follow the links below for detail explaination on load balancing.
For IGRP & EIGRP
http://www.cisco.com/warp/public/103/19.html
For OSPF
http://www.cisco.com/warp/public/105/loadbal_cef.html
For BGP
http://www.cisco.com/warp/public/459/40.html
After understanding your need, BGP should be the best choice for your network.
**Pls Rate All Helpfull Posts**
Rgs,
Jack
jackthumar
Hi Manjunath,
Routing protocols are capable of load-balancing.
AFAIK, you have two equal paths, so u can do it with OSPF. just configure the OSPF protocol and give following commands.
Router(config)#router ospf
Router(config-router)#maximum-paths ?
<1-6> Number of paths
where x is the number of available paths.
To verify the config, give
Router#show ip cef
OR
Router#show ip route
remember, this will work only for equal cost. For unequal cost, you can do load-balancing by IGRP or EIGRP protocols.
Hope this helps you, if i have misunderstood you then you can explain your need in detail.
Rgs,
Jack
Hi Jack,
Do u have any link for load balancing through the following protocols.
1.EIGRP
2.IGRP
3.OSPF
4.BGP
Rgs,
Manju
Hi Manju,
For IGRP & EIGRP
For OSPF
For BGP
Rgs,
Jack
