Join Customer Connection to register!
455
jasonkwang
Beginner
Load balancing voice vlans between two Cisco4506
I have try load balancing different voice vlans on 2 Cisco 4506 using hSRP and it don't work. Wonder any one have try out this ! Or is it that voice does not support asymmetric routing
4 REPLIES 4
leonvd79
Enthusiast
HSRP forwards all IP traffic. I can't help you without configuration details.
Please post your configuration.
--Leon
Here is the config
What exactly is your topology?
If you have two 4506s as a core or distribution layer, with multiple access switches attached... and are trying to set each 4506 as the HSRP DG for alternate subnets this will work to load balance the traffic, but only if your STP topology mirrors your Layer 3/HSRP setup.
Basically what this comes down to is that if 4506-A is the HSRP active member for VLAN1, it should also be the STP root for VLAN1. Likewise, if 4506-B is the active HSRP member for VLAN2, then is should be the STP root for VLAN2.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
mahmoodmkl
Rising star
It is simple as you configure HSRP for data vlans.
for eg:
on u r first 4506 try this
interface vlan 2
ip address 10.1.1.2 255.255.255.0
standby 1 ip 10.1.1.1
standby 1 priority 100
standby 1 preempt
and on second
interface vlan 2
ip address 10.1.1.3 255.255.255.0
standby 1 priority 150
standby 1 preempt
and one thing i would suggest is that is ur both switches are core.if they are core make sure that u configure one as root for the vlans and second as secondry root for the vlans.
Mahmood
