Logging Discriminator
jackykw123
Dear Sir,
I have problem with the C9200 log discriminator setting. It seems the length of the paramter is liminted to 40 characters.
Could you tell me what can I do if I want to filter additional messages ?
This is the current setting , the character has been truncated if the parameters longer than 40 characters.
logging discriminator DROP-LOG mnemonics drops COMM_FAILED|AUTH_RENEW|PROCPATH|SL_MESSA
logging buffered discriminator DROP-LOG
the logging discriminator has some limitations, unfortunately, such as the one you ran into. Your only option is to shorten the mnemonic matches. How many 'OR' operators do you want to include, that is, what should the full discriminator look like ?
--> logging discriminator DROP-LOG mnemonics drops COMM_FA|AUTH_R|PROCPATH|SL_M
HI Georg,
Finally I have shorten the mnemonic keyword likes this to match the requirement.
logging discriminator DROP-LOG mnemonics drops COMM_F|AUTH_R|PROC|SL_M|AUT|KEY
Jacky
