Loopback on Catalyst 3548
mmeeks
Can a loopback interface be created on the 3548 switch using IOS 12.0(5.2)XU?
mohammedmahmoud
Level 11
Level 11
The 3548 is not a Layer 3 switch, it won't support loopback interfaces.
HTH, please rate if it does help,
Mohammed Mahmoud.
Michael,
As Mohammed stated loopback interfaces aren't supported on layer 2 switches. The reason why it doesn't support loopback int on layer 2 switch is because there's no benefit in having one as the VLAN interface itself is a virtual interface.
Sundar
Thanks for the validation of what I was thinking.
