01-18-2022 03:50 PM
I have a stack of two C9300-48P. If one of the redundant power supply loses power, will the switch continue to function at full capacity?
Solved! Go to Solution.
01-19-2022 08:45 AM
Since both PSUs are 715WAC, you should have no issues when one of them fails.
01-18-2022 04:12 PM
Depends on the size of each of the PS.
The "minimum" requirement for each switch is about 375wac. When I say minimum, I mean ONLY the switch and PoE is not even in consideration.
01-18-2022 04:37 PM
01-18-2022 08:35 PM
The default power supply for that switch is 715WAC. So, as long as the second power supply is also 715WAC, you should be fine.
See table-3 in this link:
01-19-2022 08:40 AM
Thanks for everyone's input. Both ps on the switch are 715W so I should be safe to have one of them down.
01-19-2022 08:45 AM
