Lose Configs when stacking switches
pugster73
I have 2 cisco 3750 switches not stacked, each with its own config but I would like to stack them.  If I shut them off, put in the cables together and boot up, would I lose the configs of both switches and have to reconfigure the switches?  TIA.
Joseph W. Doherty
You'll "lose" the config of the 2nd switch that joins the stack.
The 2nd switch will appear as another set of ports that you can configure.
Joseph W. Doherty
Thanks for that information.
Reza Sharifi
Use this guide to build your stack. It is probably a good idea to backup your config as port assignment will change. Also, you may need to modify your config, copy and paste it back to the switch after the stacking is done.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html#anc14
