Losing connectivity with etherchannel
mbujnak01
I have a problem with connecting two ESXI servers.
If I connect them by two single links across 4 switches, everything works fine. But if I add those interfaces into port-channel connectivity doesn't work.
Do you guys have any idea what could be a problem?
Thanks.
I don't issue with the configuration. On your picture, bond1.405, it says that vlan=yes. Does this mean the packets are tagged?
If it does, then you need to trunk this port-channel too.
thx,
dsu
10 Replies 10
davidsudjiman
Can explain "If I connect them by two single links across 4 switches"?
What's the port-channel config on your switch and what's on your ESXI?
rdgs,
David Sudjiman
sorry, its not esxi, it is blade server in chasis. Servers are connected via interfaces Gi1/0/3 and Gi2/0/3 in "blade chasis" switches. If they are not int port-channel everything works.
But when I put them into port-channel I loose connectivity.
Topology and configuration is in attachment.
Thank you.
I don't see portchannel config on provided picture?
Have you followed:
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1004048
BR,
Dragan
HTH,
Dragan
Its not esxi server but IBM HS23 blade center server with Oracle Linux 6.5. (my mistake in original post)
Port-channel config is in the middle of the picture.
If I see correctly you are doing LACP (802.3ad) bonding on linux...why don't you configure etherchannel on cisco as LACP (active) also and not static ON?
BR,
Dragan
HTH,
Dragan
I did ... here is configuration
SW2#show run int gi1/0/3
interface GigabitEthernet1/0/3
 description Server2_HB1,2_prim
 switchport access vlan 405
 switchport mode access
 switchport nonegotiate
 spanning-tree portfast
 channel-protocol lacp
 channel-group 14 mode active
end
SW2#show run int gi2/0/3
interface GigabitEthernet2/0/3
 description Server2_HB1,2_sec
end
interface Port-channel14
end
But its not the problem...
Your configuration seems to be OK for port-channel LACP. Am I correct to assume that you're not doing 802.1q trunking?
thx,
dsu
Yes, you are correct.
I believe there is no need for trunk as I only need vlan 405 for those servers.
thx,
dsu
Thank you very much.
I changed to VLAN=no  and it works fine now.
