LWAPP 1231G-A-K9 Reset to a stand alone AP?
davidc_86
hello i was wondering if anyone can tell me an easy way to reset a LWAPP 1231G-A-K9 back to a stand alone unit? i have three an they are light weight, i was hoping to change them back?
2 Accepted Solutions
Hi David,
that should be quiet easy, please try this...
- Download the standalone IOS Image you want to use.
- Unplugged the power hold the mode button and put the power back on.
- Hold the mode button for at least 20 second.
- The AP now has an ip address of 10.0.0.1 and is looking for the file :
    ftp://255.255.255.255/c1240-k9w7-tar.default
   place a tftp server with the file in the subent 10.0.0.0/8 and the AP will automatically upload  the IOS file to the AP and after a automatic reboot of    the     AP and is back with an normal IOS
regards,
Sebastian
if that help, pls. rate..
I prefer tftp32 (32bit) or 64(64bit) depends on your workstation or server.
After you start the tool it select your NIC and IP automatic.
Put the IOS file in the diectory you see there or choose the directory you want in the tool.
Disable your local firewall or open the necessary ports.
thats all, you will see after the startof tha tool, the tool is quiet easy.
regards,
Sebastian
Hi David,
regards,
Sebastian
Hey , can you give me a quick rundown on how to set up a  tftp server? i have downloaded the firmware i want to use. thank you
regards,
Sebastian
Thank you very much, i googled it and used SolarWindsTFTPServer. thanks again
