02-12-2010 05:01 AM - edited 03-06-2019 09:41 AM
i have 3 cisco 871 routers, are there examples of such on this huge site ?
i can reach from the clients to the server with the two clients but not from the server to the clients thats why i want to chance it.
jilles
02-12-2010 07:24 AM
Are you able to ping the local ethernet ip of the remote routers from the central server?
Also can you do a trace from the central site server and check where the packets are getting dropped ?
If you have enabled any local firewall in your remote client PCs can you chek and disable during testing process?
regds
02-12-2010 07:44 AM
i have checked the cisco site.
you kan make two way traffix if i use network extension. but if i chance from client mode to network extension from the vpn remote i have a tunnel but no connection.
