10-02-2017 01:29 PM - edited 03-08-2019 12:14 PM
ı have 2000 swtich 10 vlan cctv iphone,access card,printer,client computer.I have for cctv camera mac address so ı wanto be one time all cctv camera all mac adress change our switch vlan.How ı do? Our 2500 cctv camera one time all camera all switch how can ı do change vlan on the switch
thank you
10-02-2017 01:51 PM
You maybe able to do this with some sort of management tool like Cisco prime. Other than that you would have to change the vlan manually per switch.
10-02-2017 02:02 PM - edited 10-02-2017 02:19 PM
I know it can be done using NCM on Solarwinds Orion, you create a script, select the switches and set up the date and time to apply the changes.
I have not used Cisco Prime but you could verify its tools as Reza mentioned.
Please don't forget to rate or mark as answered if the comments are useful
10-02-2017 10:22 PM
Hi thank you for back, ı know NCM modul ı can peer switch but ı dont know whic switch whic port plug camera i need looking arp table automatic after change vlan than need
