Maximum console cable distance between PC & Router/Switch
Anand Narayana
Level 6
Level 6
What is maximum console cable distance between a Router/Switch & PC if i make it manually? bcoz in my remote center there is no laptop with the engineer, so when ever he wanted to check the router/switch via console he need 2 shift the pc near the router/switch, so instead i told him 2 make it manually done & it works fine, but i also wanted to know what is the limited allowed distance.
6 Replies 6
mtechnology
Hi Anand,
What i generally do in these scenarios is that i connect the console serial port to any RJ-45 jack (used for ur n/w connectivity near ur PC) and extend it to the switch/router console with the existing cat cable.
And i have used it successfully over 60 meters
Narayan
andrew.burns
Level 7
Level 7
Console cables follow the RS-232 spec, so depending on speed you have the following:
speed m ft
9600 30 100
19200 15 50
38400 7.5 25
57600 5 16
115200 2.5 8
The full Cisco cabling guide with pinouts is here:
http://www.cisco.com/en/US/products/hw/routers/ps332/products_tech_note09186a0080094ce6.shtml
Andrew.
Thanks Narayan & Andrew, it was usefull & also i can share this info to others.
Despite what the recommended is, it is still possible for it to work over longer distances. I've managed to get one working over a distance of ~120M, from the 4th floor down to the basement, without any issues.
HTH,
Paolo
You have informtation about distance cable console
Please send link doumentation CISCO or RS232 about distance
