Maximum number of layer 3 switch in a single ospf area
sarb_sharmin
please let me know the maximum number of layer 3 switch in a single ospf area?
Peter Paluch
If you are asking about the maximum number of OSPF routers in a single OSPF area, technical limits are in orders of thousands. With today's routers whose CPUs and memory have enough processing power and capacity, the old tales of "no more than 50 routers per OSPF area" do not hold anymore.
How many routers/L3 switches speaking OSPF do you expect to have in a single area? What counts more is how often does the topology or the addressing change in this area, because each such change leads to a new SPF computation on all routers in the area.
Best regards,
Peter
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Practical maximums vary.  Depends much on the complexity of your topology, its stability, your needs for convergence speed, etc. With newer IOSs (e.g. those that support ISPF) you might go even larger.
An old recommendation was no more than 50 routers per OSPF area, but I've worked with OPSF areas containing (low) hundreds of L3 switches within the same OSPF area.
