01-16-2013 07:29 AM - edited 03-07-2019 11:07 AM
Could you please let me know how many VLANs can be added on trunk port on cisco switches (Maximum VLANs that can be allowed on trunk ports of a cisco switches)??.
Thanks & Regards,
Ahmed Umair
01-16-2013 07:32 AM
its the number of vlans supported by the switch.by default all the vlans are added on the trunk ports
01-16-2013 07:34 AM
A trunk port by default allows all VLAN to be passed over it. But also trunk port could be configured to allow only certain VLANs.
int g0/0
switchport mode trunk
switchport trunk allow vlan 10-20
Verification:
show interface trunk
This will show you which VLANs are allowed on that port.
Hope it will help.
Best regards,
Abzal
01-16-2013 07:50 AM
Hi All,
Thanks you very much for your support.
I totally agree with that we can allow certain VLAN on trunk port with the help of above configruation.
Int Gig0/0
switchport trunk allow VLAN add 10-15
But my question is how many VLANs we can allow on trunk port?
And How many VLANs we can create on Cisco 3750 & 6500 Series Switch.
Thanks & Regards
Ahmed Umair
01-16-2013 07:56 AM
You can check the maximum VLANs locally created on a switch by issuing a 'show vtp status' command.
01-16-2013 07:57 AM
Those swithces supports up to 4094 VLANs. And there is some specific ranges of VLANs.
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t15/ht_xvlan.html
As I said you can simply verify it with this command:
sh int trunk
If you have one of those model switches.
Hope it will help.
Best regards,
Abzal
01-17-2013 10:08 AM
If you are running PVST/PVST+, your limitation will likely be the maximum number to spanning-tree instances. See this blog post for more details:
