ME-3600X-24TS-M me360x-universalk9-tar.152-2.S.tar
lerner cisco
Hi ,
I am looking information  on the metro ethernet switch ,  the IOS going to load is   me360x-universalk9-tar.152-2.S.tar
As I checked  IOS fetaure of this file ,  it not included  EIGRP ( file is attached) .   cisco documentation says to run the routing protocol   need IP base license
at cisco configuration tool ,  while ordering the switch  ,  the tool says  the IP base license   ME3600X-I  is default product  and no need to order separately.
would llike to check  am I  good with this to run EIGRP routing protocol   with loaded image : me360x-universalk9-tar.152-2.S.tar
Thnak you
Lerner
InayathUlla Sharieff
4     ME 3800X Supported Features per License
Metro Ethernet Services (Universal Image)
Metro IP Services license
Metro Aggregation Services license
Basic Layer 2 features (including 802.1d and 802.1Q)
EVCs
Ethernet OAM—802.1ag, 802.3ah, and E-LMI
MST, REP, Flex Links
Synchronous Ethernet with Ethernet Synchronization Messaging Channel (ESMC)
All features in the Metro Ethernet Services image
IPv4 routing—RIP, OSFP, EIGRP, IS-IS, and BGP
BFD
Multicast routing—PIM, DM, SSM, and SSM mapping
Multi VRF-CE with service awareness (ARP, ping, SNMP, syslog, traceroute, FTP and TFTP)
All features in the Metro IP Services license
MPLS
MPLS traffic engineering and Fast Reroute
MPLS OAM
MPLS VPN
EoMPLS
Pseudowire redundancy
Virtual Private Network (VPLS)
http://www.cisco.com/en/US/docs/switches/metro/me3600x_3800x/software/release/15.2_2_S/release/notes/ol26699.html#wp922169
Inayath
*Plz rate if usefull.
EVCs
BFD
MPLS
MPLS OAM
MPLS VPN
EoMPLS
Inayath
Hi Sharieff ,
I gone throgh this , If you see attached fetaure set , I am no where seeing  other IPV4 routing protocols except OSPF  for the IOS  me360x-universalk9-tar.152-2.S.tar   , here I have concern .  if you tested it   then please let me know
me360x-universalk9-tar.152-2.S1.tar
me360x-universalk9-tar.152-2.S2.tar
Cisco ME 3600X universal cryptographic images. These images have the Metro IP access features plus Kerberos and SSH.
Lerner
All,
Image Name:            me360x-universalk9-mz.152-4.S.bin
Image Feature:         IP|LAYER_3|PLUS|SSH|3DES|MIN_DRAM_MEG=128
Module name = me3600 Next reboot level = MetroIPAccess and License = MetroIPAccess
it supports , by default  license  Metro IP access  with IOS  , I am able to configure  EIGRP
thank you
Lerner
