07-19-2014 06:46 AM - edited 03-07-2019 08:07 PM
Hi all, I’ am bit new to ME series switches kindly assist how should be trunking configured properly.
I have two switches SW1 and SW2 in daisy chained (meaccess 3400 series); each has their own separate vlan. And both vlan’s in uni-vlan community and each switch has trunk ports (int gi) that allow respective vlan ID’s. Then I have set up sub-interfaces and dhcp service from the router. Vlan in SW1 is working fine and user’s receive lease IP but vlan in SW2 is not.
thanks,
Solved! Go to Solution.
07-19-2014 08:17 AM
07-19-2014 08:17 AM
Can you post the configs from both switches?
07-20-2014 10:42 PM
Hi Reza,
Kindly see below
2800 series Router Config:
interface GigabitEthernet0/1
no ip address
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.0
no snmp trap link-status
interface GigabitEthernet0/1.101
encapsulation dot1Q 101
ip address 192.168.101.1 255.255.255.0
_______________________________
SW2
interface FastEthernet0/1
switchport access vlan 100
interface FastEthernet0/2
port-type nni
switchport mode trunk
switchport trunk allowed vlan all
interface GigabitEthernet0/2
port-type nni
_________________________________________
SW1
switchport access vlan 101
port-type nni
thanks,
07-21-2014 10:30 PM
Hi again,
i have tried to create same VLAN for two switches and router is able to lease ip to devices connected to SW2
this looks issue on the port-type or vlan uni-vlan type..and i think i have missed commands
please advise..thanks
