Hello colleagues,
We noticed packet loss on ME3600X 24FS
It is transit fragmented mpls labeled packets loss on ME switch.
For example: we have next scheme
prom20 (7609) --- prom20-2 (ME3600) --- novaya-sw-1 (3750me) ---
> zyx_ies1248 (target for ping)
1. When we ping from novaya-sw-1 to zyx_ies1248 – there is no packet loss
novaya-sw-1#ping 172.31.168.197 size 1500 rep 1000
Sending 1000, 1500-byte ICMP Echos to 172.31.168.197, timeout is 2 seconds:
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 1/2/17 ms
novaya-sw-1#ping 172.31.168.197 size 2500 rep 1000
Sending 1000, 2500-byte ICMP Echos to 172.31.168.197, timeout is 2 seconds:
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 1/5/302 ms
2. Ping from me3600 without loss
prom20-2#ping 172.31.168.197 sou 172.31.232.255 size 1500 rep 1000
Packet sent with a source address of 172.31.232.255
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 1/2/16 ms
prom20-2#ping 172.31.168.197 sou 172.31.232.255 size 2500 rep 1000
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 1/4/84 ms
3. Ping from 7600 to end of the link – packets loss exist on ONLY FRAGMENTED LABELED MPLS packets
prom20#ping 172.31.168.197 sou 172.31.175.193 siz 1500 rep 1000
Packet sent with a source address of 172.31.175.193
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 1/1/12 ms
prom20#ping 172.31.168.197 sou 172.31.175.193 siz 2500 rep 1000
Success rate is 98 percent (981/1000), round-trip min/avg/max = 1/4/92 ms
prom20#trace 172.31.168.197 sou 172.31.175.193
Tracing the route to novaya-ies1248-1.mgmt.redcom.net (172.31.168.197)
1 212.19.1.190 [MPLS: Label 698 Exp 0] 0 msec 0 msec 0 msec
2 novaya-sw-1-gi1-1-1.redcom.net (212.19.1.178) 4 msec 0 msec 4 msec
3 * *
3. Ping from 7600 to me3600 – without loss:
prom20#ping prom20-2 size 1500 rep 1000
Translating "prom20-2"...domain server (212.19.2.1) [OK]
Sending 1000, 1500-byte ICMP Echos to 212.19.0.54, timeout is 2 seconds:
prom20#ping prom20-2 size 2500 rep 1000
Sending 1000, 2500-byte ICMP Echos to 212.19.0.54, timeout is 2 seconds:
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 1/2/48 ms
LFIB on me3600 for interface to 3750me:
prom20-2#sh mpls forw int gi0/1
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
521 687 172.17.254.8/29 0 Gi0/1 212.19.1.178
577 639 172.30.68.44/30 0 Gi0/1 212.19.1.178
599 2618 172.30.69.44/30 0 Gi0/1 212.19.1.178
615 81 172.30.70.208/28 0 Gi0/1 212.19.1.178
671 2432 172.31.136.80/29 0 Gi0/1 212.19.1.178
680 1853 172.31.136.160/28 \
698 Pop Label 172.31.168.192/28 \
59411830 Gi0/1 212.19.1.178
740 1679 172.31.171.176/28 \
797 1998 172.31.175.160/28 \
804 2276 172.31.175.240/28 \
805 1170 172.31.176.0/21 0 Gi0/1 212.19.1.178
820 1956 172.31.193.8/29 0 Gi0/1 212.19.1.178
821 495 172.31.193.16/29 0 Gi0/1 212.19.1.178
837 129 172.31.193.184/29 \
862 Pop Label 172.31.194.232/29 \
30312 Gi0/1 212.19.1.178
941 Pop Label 212.19.0.15/32 7501818396 Gi0/1 212.19.1.178
946 1372 212.19.0.20/32 0 Gi0/1 212.19.1.178
989 1911 212.19.0.71/32 0 Gi0/1 212.19.1.178
1038 2187 212.19.1.148/30 0 Gi0/1 212.19.1.178
2833 Pop Label 212.19.25.32/30 7210 Gi0/1 212.19.1.178
2850 2473 212.19.26.28/30 0 Gi0/1 212.19.1.178
LFIB from 7609 to me3600:
prom20#sh mpls forw int te8/2
Label Label or VC or Tunnel Id Switched interface
231 2833 212.19.25.32/30 0 Te8/2 212.19.1.190
523 Pop Label 212.19.1.176/30 0 Te8/2 212.19.1.190
1560 Pop Label 212.19.0.54/32 165617 Te8/2 212.19.1.190
1655 698 172.31.168.192/28 0 Te8/2 212.19.1.190
1917 862 172.31.194.232/29 0 Te8/2 212.19.1.190
2192 941 212.19.0.15/32 7011643469 Te8/2 212.19.1.190
3496 Pop Label 172.31.232.255/32 0 Te8/2 212.19.1.190
We've done a lot of tests with software versions, MTU, ip mpls mtu, ip mtu size changing but haven't got any luck.
Also there does not any drops / discard / miss etc. on interfaces.
Thanks.
Best regards, Konstantin.
Hi Konstantin,
Just wondering if you tried a quick test setting the ICMP timeout to more than 2 seconds (e.g. 3 or 5) for ping where you see drops. This is to make sure that we indeed missing replies and not just delay those due to fragment re-assembeling.
Nik
Thank you for reply.
prom20#ping 172.31.168.197 sou 172.31.175.193 siz 2500 rep 1000 tim 3
Sending 1000, 2500-byte ICMP Echos to 172.31.168.197, timeout is 3 seconds:
Packet sent with a source address of 172.31.175.193 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.!!!!!!!!!!!!!!!!!!!!
Success rate is 98 percent (981/1000), round-trip min/avg/max = 1/4/60 ms
prom20#ping 172.31.168.197 sou 172.31.175.193 siz 2500 rep 1000 tim 5
Sending 1000, 2500-byte ICMP Echos to 172.31.168.197, timeout is 5 seconds:
Success rate is 98 percent (980/1000), round-trip min/avg/max = 1/4/16 ms
hey, i replaced a ME6524 with ME3600x and i got the same problems. Next to the ME3600x are other ME6524 Switches and they work fine. On the ME3600x i cant´s see any giant packets!!???
he´re my interface config
int gi 0/1
mtu 9000
ip mtu 1500
ip addr..
mpls ip
mpls label protocol ldp
any idea?
You can try checking following command for all interfaces in the path:
show interface GiX/Y switching (where X/Y is the mod/port numbers - please also not try to use ? for this command - it is hidden - just copy paste). You can see by that if any interface is sending the packet to RP (CPU) and we get drops there.
By that we can narrow down it to particular node.
Nik
Thank you for your reply but there is no drops anywere.
But I found one interesting thong.
ME3600X drop Checksum 0xFFFF packet when act as a label disposition LSR | |
Symptoms: Cisco ME3600X act as a label disposition Edge-LSR. When received MPLS packets with Checksum 0xFFFF that will keep continue drop with Ipv4HeaderErr and Ipv4ChecksumError at Nile.Conditions: This symptom is seen while label pop action at the Edge-LSR.Workaround: There is no workaround |
I suppose we faced with this bug, didn't I?
The Nile HW forwarding ASIC used by ME3600 doesn't support fragmentation in hardware so it punts the packet that need fragmentation to CPU queue 20 i.e. ip_mpls_mtu_fail_q.
The CPU queue has rate-limiting policer because of which intermittent packet drops happen ME-3600X
#sh pl qos policer cpu 20 0 ########### Stats for CPU queue 20 ########## Internal Qnum: 18196 Policer conform: 99 (packets) 150381 (bytes) Policer exceed: 1 (packets) 1519 (bytes) RM Drops: 1 (packets) 1547 (bytes) #############################################
ME-3600X#
This is root-cause of drops that we are seeing.
ME-3600X#
This is root-cause of drops that you are seeing.
Was there ever a fix action found for this? I think I may be running into the same issue.
