105
Beginner
Memory and Booting question about SUP720
What is the different between sup-bootflash and sup-bootdisk on sup720??
There is one file in sup-bootflash and sup-bootdisk. File name is cr1.
I teseted that deleting  one file from sup-bootdisk.
After that, i check sup-bootflash directory and I relized there'no 'cr1' file
It seems to me same. Am I right?
Router#dir sup-bootflash:
Directory of sup-bootdisk:/
    1  -rw-    33554432   Dec 6 2013 02:36:22 +00:00  sea_console.dat
    2  -rw-           0   Jan 8 2015 08:26:24 +00:00  cr1
    3  -rw-    33554432   Nov 8 2013 05:09:50 +00:00  sea_log.dat
    4  -rw-    65619456   Jan 8 2015 08:29:22 +00:00  cr11
    5  -rw-   113491268  Dec 30 2014 01:15:28 +00:00  s72033-ipservicesk9_wan-mz.122-33.SXI12.bin
512106496 bytes total (265068544 bytes free)
Router#dir sup-bootdisk:
Router#dele sup-bootdisk;cr1
Delete filename [cr1]?
Delete sup-bootdisk:/cr1? [confirm]
Router#
One more question
RP rommon mode, why sup720 doesn't show me the file directory?
Cat6k-Sup720/RP platform with 524288 Kbytes of main memory
rommon 1 > dir bootflash:
         File size           Checksum   File name
rommon 2 > dir bootdisk:
bad device name (Device not supported)
usage: dir <device>
rommon 3 > dir sup-bootdisk:
usage: dir <device>
rommon 4 > dir sup-bootflash:
usage: dir <device>
rommon 5 >
 //  I don't have disk0 and disk1 //
but i can see when SUP720 is on SP rommon mode, it shows the files.
In this situation, How can i specify boot file ?
3 REPLIES 3
VIP Expert
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Earlier sup720s had bootflash (64KB?), which was too small to contain later IOS images.  So, Cisco provided a upgrade kit that provided a larger "bootdisk" that took the place of bootflash, they also map the latter (name) into the former.  (Also, newer sup720s come with bootdisk too.)
Besides bootflash and bootdisk being determined by which is physically on the sup card, I believe processor boot ROM version images come into play.
Your other question about SP vs. RP boots, is also a bit of a muddle.  Original setups (old hybrid mode) has SP boot for L2 and RP boot for L3, now the normal (native mode) manages both, and appears to hide (or rename, or make inaccessible?) some SP flash when IOS is controlling device.  So, when you access the two different processors, there can be differences in what they "see".  I.e. there's a bootflash for both, but the newer native mode IOS images don't use SP bootflash, I believe.
Beginner
Thank you for your reply.
Can I ask you one more question? Can you explain what exactly miniIOS is ?
I saw doc it says config-register 0x2101 is miniIOS mode.
What is miniIOS? Rreloading with 0x2101, system goes into rommon. looks like normal rommon mode.
Can you help me ?
Thank you in advance : )
VIP Expert
Disclaimer
Posting
I don't recall miniIOS (or RXBOOT) being supported on the 6500 series.
7200s, I recall, used to support a special IOS to be loaded into their bootflash.
See page 2's "Types of Images" in http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sys-image-mgmt/configuration/15-mt/sysimgmgmt-15-mt-book/sysimgmgmt-imgs.pdf
Content for Community-Ad
July's Community Spotlight Awards
