Beginner
Memory on Ro_01 has insufficient capacity or is malfunctioning
Hi ,
Can some please advise about the following alert i am seeing on HP open view (Hp openview is used to monitor the network):
Memory on RO-)1 has insufficient capasity or is a malfunctioning.
I am not seeing any thing in the logs can some please advise what is this alert and how to troubleshoot this .
regards,
KZ
6 REPLIES 6
Participant
try issuing the following command on the router:
sh proc memory
this should tell you how much memory is being utilized by the router at that point of time and generally log are not generated for the memory exhaustion.
Neeraj
Beginner
Hi Neeraj,
Thanks for the reply could you please advise on the below output:
Ro_01#sh proc memory
Total: 89418496, Used: 25631188, Free: 63787308
PID TTY Allocated     Freed   Holding   Getbufs   Retbufs Process
   0   0     104064       1848   15635248         0         0 *Init*
   0   0       964   19406664       964         0         0 *Sched*
   0   0 2530581116 2508272696   3952932   2817844         0 *Dead*
   1   0       284       284       3828         0         0 Load Meter
   2   2     449380     419344     43080         0         0 SSH Process
   3   0       736       456       7264         0         0 IpSecMibTopN
   4   0         0     15120       6828         0         0 Check heaps
   5   0         96         0       6924         0         0 Chunk Manager
   6   0         96   7363112       6924         0 180182924 Pool Manager
   7   0       284       284       6828         0         0 Timers
   8   0       284       284       6828         0         0 Serial Backgroun
   9   0         96         0       3924         0         0 OIR Handler
10   0         0         0       6828         0         0 ALARM_TRIGGER_SC
11   0         96         0       6924         0         0 IPC Zone Manager
12   0         0         0       6828         0         0 IPC Periodic Tim
13   0        0         0       6828         0         0 IPC Deferred Por
14   0   23559884     60504     21696         0         0 IPC Seat Manager
15   0       1840     477672       7720         0         0 ARP Input
16   0         0         0     6828         0         0 HC Counter Timer
17   0       284       284       6828         0         0 DDR Timers
18   0       284       284     12828         0         0 Dialer event
19   0     25092       4360     27560         0          0 Entity MIB API
20   0         96         0       6924         0         0 SERIAL A'detect
21   0       1108         0       7936         0         0 Microcode Loader
22   0       7432         0     14260         0         0 Critical Bkgnd
23   0   3595780     35604     15512         0         0 Net Background
24   0   2274652       300     12924         0         0 Logger
25   0       4928   2375212       6828         0         0 TTY Background
26   0         0   2387944       9828         0         0 Per-Second Jobs
27   0         96         0       3924         0         0 Inode Table Dest
28   0         96         0       3924         0         0 Inode Table Refr
29   0      248         0       7076         0         0 IP Crashinfo Inp
30   0       136         0       6964         0         0 DSX3MIB ll handl
31   0       924       284     7468         0         0 VSI Master
32   0     24424       284     30968         0         0 VNM DSPRM MAIN
33   0         0         0       6828         0         0 RSP Background
34   0         0         0       6828         0          0 Memory Scanner
35   0 427055672 427055672       3828         0         0 Slave Time
36   0         96         0       6924         0         0 Slave IPC OIR
37   0         96         0       6924         0         0 CRYPTO IKMP IPC
38   0         0         0       3828         0         0 Chassis Daemon
39   0         0         0       6828         0         0 RSP Chassis Back
40   0       476       284       7020         0         0 MIP Mailbox
41   0         96        0       6924         0         0 vcq_proc
42   0         96         0       6924         0         0 CT3 Mailbox
43   0         96         0       6924         0         0 CE3 Mailbox
44   0         96         0       6924         0        0 HAL Mailbox
45   0         96         0       6924         0         0 SRP Event Proc
46   0         96         0       6924         0         0 IPC CBus process
47   0       532       284     13076         0         0 ATM OAM Input
48   0       284       284     12828         0         0 ATM OAM TIMER
49   0       380       284     12924         0         0 TurboACL
50   0       380       284       6924         0         0 AAA Dictionary R
51   0       380      4920       6924         0         0 AAA Server
52   0         0       4852       6828         0         0 AAA ACCT Proc
53   0         0         0       6828         0         0 ACCT Periodic Pr
54   0   86876540 4072109024     415056   27924480         0 IP Input
55   0         0         0       6828         0         0 ICMP event handl
56   0       440         0       7312         0         0 LAPF Input
57   0       532       284     13076         0         0 PASVC create VA
58   0         96         0       6924         0         0 PPPATM Session d
59   0       532       284       7076         0         0 MOP Protocols
60   0       192         0       7020          0         0 X.25 Encaps Mana
61   0       380       284       6924         0         0 KRB5 AAA
62   0         0         0       6828         0         0 LDP Background
63   0         0         0     12828         0         0 frr_tunnel
64   0         0         0     12828         0         0 VPDN call manage
65   0       136         0     12964         0         0 L2X Socket proce
66   0      448       284       6992         0         0 IP Hdr Comp Proc
67   0     200780   3432172     75640         0         0 IP Background
68   0         0         0       6828         0         0 SNMP Timers
69   0     35296   6516108     12912         0         0 TCP Timer
70   0   79150124   96018444     20896         0         0 TCP Protocols
71   0         96         0       6924         0         0 RARP Input
72   0         0         0       6828         0         0 HTTP Timer
73   0         0         0       6828         0         0 Socket Timers
74   0     41068     11136     23104         0         0 DHCPD Receive
75   0       272         0       7100         0         0 Probe Input
76   0          0 4203890856       6828         0         0 IP Cache Ager
77   0       1316         0     26144         0         0 COPS
78   0       284       284     12828         0         0 PPP Hooks
79   0         0         0     12828          0         0 PPP IP Route
80   0         0         0     12828         0         0 PPP IPCP
81   0       248         0       7076         0         0 PAD InCall
82   0       380       284     12924         0         0 X.25 Background
83   0         0         0       6828         0         0 TCP Intercept Ti
84   0       284       284       6828         0         0 SPX Input
85   0       532      284       7076         0         0 Adj Manager
86   0     842860     404544     394788         0         0 CEF process
87   0     14032         0       6924         0         0 MDFS RP process
88   0       800       284       7344        0         0 TC-ATM Proc
89   0       476       284       7020         0         0 Tag Input
90   0       9292     116204     14404         0         0 IPC LC Message H
91   0       284       284       6828         0         0 Dialer Forwarder
92   0       248         0       7076         0         0 PPP Forwarder
93   0     79644       284     86188         0         0 RUDPV1 Main Proc
94   0         0         0       6828         0         0 bsm_timers
95   0          0         0       6828         0         0 bsm_xmt_proc
96   0       284       284       6828         0         0 RLM groups Proce
97   0     12132       3268       6924         0         0 LOCAL AAA
98   0       380       284       6924         0         0 ENABLE AAA
99   0       380       284       6924         0         0 LINE AAA
100   0   14741692   10700844     10480         0         0 TPLUS
101   0     112808       5048       6840         0         0 TACACS+
102   0       284       284       6828         0         0 Net Serv Timer
103   0       480         0       7308         0         0 Crypto Support
104   0         0        0     12828         0         0 Crypto SS Proces
105   0         96         0       6924         0         0 Router Autoconf
106   0     25016         0     49844         0         0 TSP
107   0     72192         0     97020         0        0 QOS_MODULE_MAIN
108   0     12580         0     22408         0         0 CCVPM_HTSP
109   0       676         0       7504         0         0 CCVPM_R2
110   0       328         0       7156         0         0 CCSWVOICE
111   0       820         0       7648         0         0 sssapp
112   0       2208         0       9036         0         0 http client proc
113   0       6180       7792     18296         0         0 Crypto ACL
114   0   3924116         0     13060         0         0 Encrypt Proc
115   0 591174188 591172812       9952         0         0 Key Proc
116   0       9480       284     18024         0         0 Crypto CA
117   0         96         0       8924         0         0 Crypto SSL
118   0 2868237480 2780166128   2481760         0         0 Crypto IKMP
119   0   61024976 146431000     187724         0         0 IPSEC key engine
120   0         0         0       6828         0         0 IPSEC manual key
121   0       1284         0       8112         0         0 SYSMGT Events
122   0     307544   2112272       7076         0         0 AAA SEND STOP EV
123   0         96         0       6924         0         0 Syslog Traps
124   0         0          0       6828         0         0 cbus utilization
125   0         0         0       6828         0         0 BUSYOUT SCAN
126   0         0         0       6828         0         0 trunk conditioni
127   0       1444         0       8272         0         0 trunk conditioni
128   0       192         0       7020         0         0 Net Input
129   0       284       284       6828         0         0 Compute load avg
130   0 158673164   23481028     63712 152039340         0 Per-minute Jobs
131   0   31189668   31189532       6980         0         0 SSH Event handle
132   0       384         0       7212         0         0 CEF Scanner
133   0     46656   1199748       9076         0         0 CEF IPC Backgrou
134   0       284       284       6828         0         0 DSS Process
135   0       496         0     13324         0         0 L2F management d
136   0       248          0     13076         0         0 L2F data daemon
137   0       248         0     13076         0         0 L2TP data daemon
138   0       496         0     13324         0         0 L2TP mgmt daemon
139   0       248         0       7076         0         0 PPPOE discovery
140   0       248         0       7076         0         0 PPPOE background
141   0     74276         0     80276         0         0 PPTP Mgmt
142   0       608      284     13152         0         0 PPTP Data
143   0       284 2292940076     12880         0         0 DLSw Background
144   0 1428954188   6365168     16644         0         0 DLSw msg proc
145   0       3704       284     16248        0         0 CLS Background
146   0 838975300   4973260     13212         0         0 DLSw Peer Proces
147   0   5178640   64051920     13352         0         0 TCP Driver
148   0       380       284     12924         0         0 HyBridge Input P
149   0       1196       284       7740         0         0 Tbridge Monitor
150   0       568       284       7112         0         0 Spanning Tree
151   0       284       284       9828         0         0 LLC2 Timer
152   0         0         0       6828         0         0 TCP Listener
153   0     238128         0       7076         0         0 FR LMI
154   0         0         0       6828         0         0 FR Broadcast Out
155   0       284       284      6828         0         0 compute load per
156   0       248         0       7076         0         0 FR ARP
157   0       324         0       7152         0         0 FR TUNNEL
158   0         0         0       6828         0         0 FR FRAGMENTATION
159   0       248         0       7076         0         0 FRF9 manager
160   0       248         0       7076         0         0 FRF9 timed event
161   0       440       344       6924         0         0 IP Flow Backgrou
162   0 1158874080 1158484296       6964         0         0 IP-EIGRP Hello
163   0         0         0     12828         0         0 PPP Events
164   0       588       284      13132         0         0 PPP manager
165   0       568       284       7112         0         0 Multilink PPP
166   0       568       284       7112         0         0 Multilink PPP ou
167   0       532       284       7076         0         0 Multilink event
168   0       568       284       7112         0         0 CCP manager
169   0       568       284       7112         0         0 CCP reset pak
170   0       400          0       7272         0         0 LAPF Output-I
171   0 2382693320 2382668912     15496         0         0 IP SNMP
172   0 3014297024       364     13076         0         0 PDU DISPATCHER
173   0 250247336 3264561056     16544        0         0 SNMP ENGINE
174   0         96         0     12924         0         0 SNMP ConfCopyPro
175   0         96         0     12924         0         0 SNMP Traps
176   0       1572       284       8116         0         0 NTP
177  0         0         0       6828         0         0 DHCPD Timer
178   0       152         0       6980         0         0 DHCPD Database
179   0 4027904368 4265152780     409504         0         0 IP-EIGRP Router
180   0       400          0       7272         0         0 LAPF timer-Ack
181   0       1064       768       7124         0         0 CDP Protocol
                                 2554502
                                 2554502
Beginner
Hi Neeraj,
Hi Neeraj,
I am also having this issue, any idea how to resolve it?
Thank you,
Hall of Fame Community Legend
sh version
Beginner
IOS (tm) RSP Software (RSP-JK9SV-M), Version 12.2(8)T5, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Mon 24-Jun-02 07:13 by
Image text-base: 0x60010948, data-base: 0x61CC2000
ROM: System Bootstrap, Version 12.0(10r)S1, RELEASE SOFTWARE (fc1)
Ro_01 uptime is 2 years, 19 weeks, 19 hours, 44 minutes
System returned to ROM by error - a Software forced crash, PC 0x60385270 at 00:09:36 GMT Sat Jan 1 2000
System restarted at 15:20:29 GMT Sat Oct 3 2009
System image file is "slot0:rsp-jk9sv-mz.122-8.T5.bin"
cisco RSP4+ (R5000) processor with 131072K/2072K bytes of memory.
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Bridging software.
TN3270 Emulation software.
Chassis Interface.
2 VIP2 controllers (4 FastEthernet)(4 Serial)(4 T1)(4 Token Ring).
4 FastEthernet/IEEE 802.3 interface(s)
4 Token Ring/IEEE 802.5 interface(s)
4 Serial network interface(s)
123K bytes of non-volatile configuration memory.
32768K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
Slave in slot 3 is running Cisco Internetwork Operating System Software
IOS (tm) RSP Software (RSP-DW-M), Version 12.2(8)T5, RELEASE SOFTWARE (fc1)
Compiled Sun 23-Jun-02 12:01 by ccai
Slave: Loaded from system
Slave: cisco RSP4+ (R5000) processor with 131072K bytes of memory.
Configuration register is 0x102
Beginner
can some one please advise what is the issue here and how to fix it
Content for Community-Ad
July's Community Spotlight Awards
