I have a pair of 4451-X routers (XE 3S) running MHSRP on a "nat inside" interface - each is active for its own group and standby for the other's group.
Each router has two "nat outside" interfaces each running a single HSRP group, and one of the routers is active (master) for both outside interfaces
I want to use nat redundancy for a number of static source nats, but the ip nat statements only take one group name, and I have two groups on my inside interface.
The only reference I can find which might have some relevance is a paper on SNAT and MHSRP:
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-software-releases-12-2-t/prod_white_paper0900aecd8052870b.html
... where it states "Note: SNAT can only listen to one HSRP group. If it is necessary to listen to multiple groups, you need to tie multiple HSRP groups to one group. "
If I am on the right track, (and it all seems a little vague), does anyone know how I would go about doing this?
Thanks in advance
