07-29-2013 02:01 PM - edited 03-07-2019 02:39 PM
So, I need to migrate a port channel to a new set of ports in the Nexus 7K. Below is the current config on the Nexus:
interface port-channel33
switchport
switchport mode trunk
switchport trunk allowed vlan 10,50
spanning-tree port type edge trunk
interface Ethernet6/33
switchport
channel-group 33 mode active
no shutdown
interface Ethernet7/33
switchport
no shutdown
Ports 6/33 and 7/33 are 10G uplinks to a pair of 2960S in a flexstack. The 2960S has the following config:
interface Port-channel5
description --==## Uplink to Nexus 7000 ##==--
spanning-tree portfast trunk
interface TenGigabitEthernet1/0/1
channel-group 5 mode active
interface TenGigabitEthernet2/0/1
I need to move the uplinks from ports 6/33 and 7/33 to 6/35 and 7/35. I would also like to change the port channel ID from 33 to 35 for naming reasons. Is there a way to accomplish this without dropping any packets? Thanks.
Dave
08-02-2013 03:04 AM
I know your point,but I never did it,so I just guess:
1.you are using PAGP in portchannel,it's great
2.creat an new PC name 35,and add 7/35 to PC-35
3.break 7/33,and connect 7/35,this time PAGP will suspend 7/35
4.shutdown 6/33,this time PAGP will use 7/35,the PortChannel takeover more faster, so it's some packet will droped really, but very few
5.connect 6/35, the PC-35 get full connection.
At step 3, if 7/35 not be suspended,you can go back, it's save, no packet droped.
I suggest you do a lab-test first,and migrate at low-traffic time window.
Whether you success,please let me know,Thank you.
08-02-2013 11:02 AM
I performed the cutover the other night. I created a new port channel 35 and added both ports 6/35 and 7/35. I then unplugged 6/33 and moved the SFP into 6/35. I then quickly just unplugged 7/33 and plugged in 6/35. I only droped 1-2 packets.
Dave
08-04-2013 05:19 PM
nice
