Missing info on web interface?
diegoalvarez1
Dear
      We're just starting to configure 2 new 3750x-24 in our datacenter. A few months a go, we put on service a 2960S and a 3750G-24, with no issues. My problem is that i configure both new switches, and everything seems ok but when i open the web console i only get this, almost empty page. We have tried different browsers and workstations. My question is there some missing config, or some option i have to enable for it to work? Ip http server is enable.
This is my basic config (without the stack, that works just fine)
switch>
swicth>ena
switch#
switch#config t
swicth(config)#hostname swn
swn(config)#enable password ---
swn(config)#enable secret ---
swn(config)#line console 0
swn(config-line)#password ---
swn(config-line)#end
swn#
swn#config t
swn(config)#line vty 0 4
swn#
swn#config t
swn(config)#interface vlan 1
swn(config-int)#ip address"ip" "mask"
swn(config-int)#no shutdown
swn(config-int)#end
swn#copy running-config startup-config
I will be grateful for any assistance you can provide.
Best regards
paolo bevilacqua
Wrong forum, post in "LAN and switching". You can move your posting with the Actions panel on the right.
pieterh
Cechkout "dir flash:".
Apart from the .bin (ios image) there needs to be a directory for the html pages.
From the cisco software download page you can select only the .bin file (iOS image)or the .tar file (complete image including web management files) for download.
Install this .tar like an iOS upgrade.
Dear
      Thank you for your response, i already verified the directory for html pages. But issue was simpler (I'm sorry to say), most of the workstations that we use trying to reach the web console, have automatic java updates enabled. I opened a remote conection to an old server, and i was abled to see the full console. I didn't expect that from a brand new switch.
Thank you again.
