MISSION VACL......Any how i need VACL to be configured......
Milan Rai
From 213 vlan everythings is dropped.............
ip access-list extended print
permit tcp any any eq 1985
permit tcp host 192.168.213.59 host 192.168.6.7 eq 1526
permit tcp host 192.168.213.60 host 192.168.6.7 eq 1526
permit tcp host 192.168.213.58 host 192.168.6.7 eq 1526
permit tcp host 192.168.213.58 host 192.168.6.7 eq 3389
deny ip any any
vlan access-map DEPT 10
match ip address print
action forward
vlan access-map DEPT 20
action drop
vlan filter DEPT vlan-list 213
this is my configuration guys,,,,,after this applied to the vlan 213 everythings is dropped even my other vlan is affected WHY??........i cant even ping the gateway.....i am sorry that i forget to mention you about HSRP ........For this 213 vlan we have configured stand by ip.........so i hope i have made you clear about my topology........
6 Replies 6
shanilkumar2003
This you should configure in vlan interface with access-group to restrict the access.
VACL can be used better to restrict access within vlan 123
Shanil
That means.......VACL is only for restricting access within the vlan???????
Actually my access-list was same what you are suggesting.....I am tryin for the more specific access list thus i need to switch to VACL....
VACLs are used to control traffic within a vlan. The acl that you have doesn't match traffic within the vlan so it hits the deny everything which is why you lose traffic. This type of acl needs to be appled to the l3 svi that's attached to the vlan. Being that you said you have hsrp configured, I'm assuming that you have a "int vlan 213". If that's the case, you'd want to not use vacls, and instead use the access list directly on the svi.
int vlan 213
ip access-group print in
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John you have given me the present scenior of my network......I have int vlan 213.....ip access-group print in
but i have problem with this tooo..........so i m tyring to go for VACL.....you will just plz tell me why i whole network gets dropped after applying the VACL to just 213.....
I explained above. In your case, the vacls method is to drop traffic that doesn't match. The vacl isn't the correct method to apply here since you are crossing vlans (I'm assuming this because of different subnets). A vacl only works when your trying to block traffic within the same vlan and not intervlan. Intervlans are going to use acls on the svi interface as stated above...
HTH,
John
Ok John then i should only be going with the ACLS on svi interface??? am i right????
ok........thanks.....i will check it out.....
