Hi all,
hope you can help me.
Have several Cisco 9300 switches configured with MKA. Everything was working correctly but some switches in the network had a power failure and restarted. All came back, but then I was having issues with OSPF disconnecting and connecting some neighbours, and when checking the MKA, I had some sessions saying "Pending" on some switches, but the neighbour that, that switch was connecting to was saying for the same interface "Secured". Rebooted the switch that was saying "Pending" and when it came back online, it returned working correctly with the interface saying "Secured" in the MKA Summary.
Any ideas as to why this might have happened? A reboot solved all the problems afterwards in the switches that weren't affected by power failure...
Thank you
