MLS on 6500 with sup2T
kthned
Participant
Participant
Cisco 6500 with 2T supervisor engine with following software
Cisco IOS Software, s2t54 Software (s2t54-IPSERVICESK9-M), Version 15.0(1)SY1, RELEASE SOFTWARE (fc4)
The problem is that, I am not able to configure Multilayer Switching (MLS) (mls rp ip) in the global config command. Although the "mls" is visible on the config menu. but when I say "mls ?", the router prompt "unrecognize command"
Not sure if SUP 2T support MLS or it come with different name .
I hope to get your comments. Thanks !
Umair
Leo Laohoo
Hall of Fame Community Legend Hall of Fame Community Legend
Try the command "ip routing".
Recognize Your Peers
