mls qos doesn´t work Switch 3560
I can´t input qos command on a switch 3560 version 15.2
This is the output:
SW(config)#mls qos
% Invalid input detected at '^' marker.
SW(config)#no mls qos rewrite ip dscp
SW(config)#
I looked up  all over the internet and can´t mutch about.
Some guy said that have the same issue when he upgraded the ios version, is that possible?
Bráulio Castigo
Mark Malone
not all 3560s support mls but if mls is not available auto qos will be , some have both some only 1 feature both generally do same thing
You should be able to confirm exactly what your version supports through feature navigator
https://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/index.jsp
Mark Malone
Hi Mark,
You are right .
Thanks!
Best Regards
Braulio Castigo
