Ask the Expert- SD-WAN
117
Molex DAC cable (747521301) compatibility with CISCO SG550XG-24F 24-Port 10G SFP+
i have  the Molex DAC cable (747521301) which comes with SPF+ modules, I need to confirm the compatibility with the
  CISCO SG550XG-24F switch, I have come across the situation where this cable doesn't work with the CISCO and mostly with catalyst switch.
Please guide how I can verify the compatibility
https://www.molex.com/molex/products/datasheet.jsp?part=active/0747521301_CABLE_ASSEMBLIES.xml&channel=Products&Lang=en-US
https://www.cisco.com/c/en/us/support/switches/sg550xg-24f-24-port-ten-gigabit-switch/model.html
1 REPLY 1
VIP Expert
Re: Molex DAC cable (747521301) compatibility with CISCO SG550XG-24F 24-Port 10G SFP+
With third party cables, it is hard to tell what cable work with what Cisco products unless you just try it. If the one you have does not work, try one from this site. Their cables seems to work with Nexus series but not sure about SG series
https://www.fs.com/c/active-optical-cables-2688
Content for Community-Ad
July's Community Spotlight Awards
