Monitering backplane utilization on 4503 with MRTG
sumanth_myneni
I am planning to monitor the backplane utilization of the Core 4503 using MRTG software. I tried with different MIB's but couldn't monitor. Please suggest me whether we can monitor that using MRTG.The software running is
_________________________________________
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.1(20)EW1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Sumanth
7 Replies 7
ebreniz
Level 6
Level 6
Yes, it is possible to monitor using MIB, but the the device name that has to be monitored should be entered in the SNMP server for periodic updates.
pmajumder
Level 3
Level 3
In your Mrtg cfg file enter the following:
Target[IP address of switch-BU]:.1.3.6.1.4.1.9.5.1.1.8&.1.3.6.1.4.1.9.5.1.1.8:readcommunity@ip address of switch
This should give you the % of backplane bandwidth utilization.
Pradeep
Pradeep
This is not working I'm afraid.
SNMP Error:
Received SNMP response with error code
error status: noSuchName
index 1 (OID: 1.3.6.1.4.1.9.5.1.1.8)
SNMPv1_Session (remote host: "10.x.x.x" [10.x.x.x].161)
community: "public-snmp"
request ID: 1868755414
PDU bufsize: 8000 bytes
timeout: 2s
retries: 5
backoff: 1)
at C:/mrtg/bin\..\lib\mrtg2/SNMP_util.pm line 490
SNMPGET Problem for .1.3.6.1.4.1.9.5.1.1.8 .1.3.6.1.4.1.9.5.1.1.8 sysUptime sysName on public snmp@10.x.x.x::::::v4only
Any ideas why?
Paul
Paul,
Any idea on how to check the backplane utlization on switch. Any command.
Suresh Jain
Hi All,
There is is not command as such available right now on Cat4500 IOS for monitoring the backplane utilization.
On the Supervisors running CatOS or IOS. Normally, you can monitor backplane utilization for CatOS switches using CISCO-STACK-MIB:
http://www.cisco.com/en/US/tech/tk389/tk816/technologies_tech_note09186a0080
094a96.shtml
However, the Catalyst 4000 (IOS) does not support CISCO-STACK-MIB. Therefore, it is not
possible to monitor backplane utilization on the Cat4000 IOS via SNMP.
HTH,
-amit singh
Thank you for your reply.
Any other ways of monitoring the backplane on Cat4500 IOS?
Paul
No as of Now, let's wait for new IP release.
-amit singh
