Monitoring Optical Module Status
zeitzytoun
How we can get all the information presented in this image through command line (the target switch is cisco sf302-08pp)
Thanks in advance.
balaji.bandi
Not sure these are SMB switches has focussed more of GUI based , not sure when you getting information GUI why you like to do same in CLI Level ? any reason ?
in enterprise switchses : ( we use below command)
show interface gig 1/1 transceiver
May be you can try below command :
show inventory
show fiber-ports optical-transceiver
here is the admin guide for referene :
https://www.storagenetworks.com/documents/cisco/cisco-series300-manual.pdf
BB
Hello, thanks for your response
these commands helps in fetching most of the columns, but we still can't get Transmitter Fault and Data Ready, do you have any idea about the way of getting them.
thanks.
Did you try
sh tech-support - full info about device (im not sure about the availability of this command in this switch)
sh inv - you can see serial number and model sfp
sh int .. tranciever detail - level, power etc
