04-22-2010 02:40 AM - edited 03-06-2019 10:44 AM
Hello
I'm going to start the evaluation of implementing the virtualization of our campus LAN using MPLS.
We'll get many inter-VLAN routing domains per VRF on the same LAN infrastructure.
The LAN infrastructure is based on C6500 implementing VSS.
Do you have experience with this kind of setup?
Any known/faced issue that might prevent the setup of MPLS on VSS enabled C6500?
Thank you
Best regards,
Andrea
04-22-2010 02:50 AM
Hello Andrea,
you will need 12.2(33)SXI2 or later to have MPLS support
VSS best practices
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c837.shtml
Hope to help
Giuseppe
04-22-2010 02:59 AM
Yes, that's already covered. thanks
>> VSS best practices http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c837.shtml
The document does no address the implementation of VRFs. It's just a light guide on the implementation of VSS.
Thanks in any case for the reply.
Andrea
04-22-2010 03:21 AM
you can start from here
Hope to help
Giuseppe
11-12-2011 08:22 PM
I am planning to run VSS on a dual PE as well.
I cant find any related configuration docs for this.
any idea?
