MPLS PWE3 tagged mode
h.otsubo
Beginner
Beginner
Could you help me?
I checked RFC 4448 but I can not understand the vlan tag handring on tagged mode PW. In my understanding, there are two methods to hundle vlan tag on PW.
(1) VLAN tag is stripped at ingress PE and is rewrited to configured tag at egress PE
(2) VLAN tag is kept on PW and is rewrited to configured tag at egress PE
Which method is standard ?
TIA,
rsimoni
Hi Tia,
you are referring to EoMPLS Pseudowire Types (which are better defined in rfc4446 and not 4448) and indeed there are 2 ways to handle tags.
VC Type 4 : The original 802.1Q tag is inserted in the EoMPLS payload (along with the MPLS label) before forwarding it to the MPLS core. At the ingress of the remote end or receiving PE the 802.1Q tag is stripped off before its transmission to the internal bus. If a packet is received from the MPLS core without a tag (ether type of the packet is other than 0x8100) the packet is dropped.
VC Type 5 : In EoMPLS VLAN mode configuration, only the MPLS label is added to the packet transmitted to the MPLS core. On the ingress of the remote end or receiving PE the MPLS label stack is popped out before the transmission on the internal bus. If Port mode is configured instead, the 802.1Q tag is also carried along with the MPLS label
The actions taken by the PE interfaces facing the CE are solely determined by the specific interface configuration. If such configuration requires 802.1Q tagging, the egress frame is tagged; otherwise the egress frame is sent untagged. EoMPLS VC type 5 is the default configuration mode on the platforms supporting it. Meaning that the PEs will try to first negotiate and use VC 5, if one of them (or both) does not support it they will reverse to VC 4. EoMPLS type VLAN offers backward compatibility in case the remote peer does not support VC type Ethernet.
VC type 4 or VC type 5 is not a configurable option and is platform dependent, the capability is instead auto
sensed at control plane level
hope it helps.
please rate and close the question if helpful
regards,
Riccardo.
Recognize Your Peers
