Mr. Anthony
akariri01
I have tried this configuration above on CISCo packet tracer
I configured all interfaces of all switches
- Trunks for all switches
-Access ports for all switches
I configured VLANS for all switches
-only two VLANS
-I associated the VLANS with switchports correctly
I configured router on a stick
- Sub-interfaces for VLAN 10 and 20 with dot1q encapsulation
-I issued IP addresses for the sub-interfaces
I configured all the PCs with the IPs and masks
I only have a problem that i cant ping other PCs....
where would i be missing out?
7 Replies 7
bogdan_butucel
Have you configured the default gateway on each PC ?
Yes. correctly configured
Can you please check one more time all configuration in switches and router
are you configured in vlans in 3 switches and what is the default gateway have you set pls check one more .
in systems also check
if it is possible  pls share your config..
vlans
trunks
svi in router
switch ip address
system side ip address
CRaju
Julio E. Moisa
Have you configured
- a trunk interface on the switch connected to the router
- Default gateway on the PCs as mentioned previously.
- The vlans created on the switches and passing through the trunk interface between the switches?.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you Julio,
I have configured the switch connected to the router with a trunk interface
I have also issued PCs with IP addresses and default gateway as well
Ping still fails.
Thank you,
Could you please share the config from router and switches?
Dennis Mink
What IP addresses are you pinging and from where?  what IP's do you have on the SVIs?
Please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
