MS NLB failing on 6509 after reboot
neil_titchener
Hi, We have an issue where MS NLB fails after a switch reboot i.e. the arp entries no longer exist and the only way around this is by removing and reapplying the configuration.  I believe our configuration isn't actually correct but I wanted to know if anyone has experienced the same issue on the same version of software or even the same configuration.
Software version is 15.0(1)SY6, running in VSS mode
Actual configuration is:
Global config
arp 172.24.1.1 03bf.ac18.1234 ARPA
mac address-table static 03bf.ac18.1234 vlan 2 interface Port-channel1
I believe the configuration should be:
Interface Vlan 2
exit
Thanks in advance
Reza Sharifi
Looking at this document, all configs are global and not under any SVIs.
If this does not work after every reboot, you may want to open a ticket with TAC as it may be a bug.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/107995-configure-nlb-00.html
